Will Someone Please Help With Canada Body Tag Decode
I just bought a new project and need some help decoding the Body Tag. I know the important stuff like it is a 442 with a close ratio M21(still has all the tags on it). It also has the white/parchment bucket seats. I'm curious what D55 option is and what the paint code CGG is. The car was originally gold but that is all I know. The car does have the bright finish drip rail mouldings. What does the 1-4-22 mean?
D55M21
ST 68 34487 OS323844 BODY
TR 947 1-4-22 CGG PAINT
D55M21
C= white, G=willow gold. When you said dark green, I first thought "Jade Gold" which is a metallic green, but you data tag says otherwise. I would get the Canadian documents, which give you everything for a car sold or built in Canada.
I do plan on getting the paperwork from Canada. Im trying to decide if I want standard or the heritage package. Www.vintagevehicleservices.com I am not doing a numbers matching restoration; what is the benefit of heritage certification?
C is the code for white, whether as the body color or for the stripe. GG means Willow Gold for the lower body color and Willow Gold for the upper body (the top). If the top were a different color, then it would be GB for example: Willow Gold with a Ebony Black top. if it were vinyl or a convertible top, then it would use a number for the color. G8 would be willow Gold with a Gold vinyl top. As you have indicated that it appears that the car was Willow Gold, then I am inclined to think that it was Willow Gold with a white stripe.
D55M21
D55M21
3 - Oldsmobile division of GM
44 - model 442
87 - 2 dr Holiday coupe
OS - Oshawa Canada Production
323844 - fisher body number
TR 947 - Parchment vinyl interior
CG - (part of a 2 tone color combination) - in this case refers to combination of Provincial white and willow gold - recommended as a color combo in the SPECS guide for 1968 production with parchment interior.
G - Willow Gold
D55 - sports console
M21 - transmission - heavy duty close ratio synchronized 4 speed; floor shift
Check them out: http://www.vintagevehicleservices.co...tion_73.45.pdf
The 'heritage' form is for documenting 'Canadian Built' cars. A wasted effort IMO since you already know your car was made in Oshawa.
http://www.vintagevehicleservices.co...ertificate.pdf
Your call.
Fyi
Isn't CGG code for Willow Gold body with Willow Gold roof & white stripes?
First letter = lower body color, 2nd letter = upper body color (top). Would the stripe be listed first or last? He has indicated that it appears to be willow gold, so why wouldn't the main color of the car be listed first. Is this spelled out in the Assembly manual? In '69 they went to a two digit paint code. Mine is 55 for Tahition Turquiose, as it is painted that color top and bottom, my data tag reads 55 55, so if his car was origianally Willow Gold top & bottom, wouldn't it be G G? Looking for definite answer/clarification, sorry if it sounds like I'm beating it to death.
Obviously, I don't know. Lol
The stripe would follow the body like the H/O, but it's about 3/8 of an inch wide, and is about a 1/2" below the trim. My buddy has a '68 442 with the stripe, but I don't have any photos that show it.
A look at some other Oshawa 442 tags will clarify this for sure.
pfergy600
September 28th, 2013 07:47 PM
