whitch electric fuel pump
Old Aug 20, 2013 | 12:22 PM
pbarney's Avatar
I have a 67 cutlass sup. w/330-325hp. To reduce vapor lock I want to install an electric fuel pump. The engine is pretty much stock and I plan to keep it that way. There are a ga-zillion pumps to choose from. What would be a good match up that's resonabally priced and not too loud.
Also, will I need a relay?
Old Aug 20, 2013 | 06:40 PM
gearhead1218's Avatar
I run Aeromotive products and am very pleased. Specifically the SS seriers pump.
But if you want to TOTALLY eliminate vapor lock, I suggest running a return style system.
Yes it will cost more, but no more VL, and the pump will run quieter and cooler.
Also power your pump with a relay.
Old Aug 21, 2013 | 07:06 AM
Run to Rund's Avatar
I have run Carter, and currently have a Holley red pump on one of my Oldsmobiles.
Old Aug 21, 2013 | 07:34 AM
D. Yaros's Avatar
Carter makes reliable/less noisy electric fuel pumps. Yes, you should run it thru a relay.
Old Aug 21, 2013 | 01:58 PM
dc2x4drvr's Avatar
I run a Holley 125, which is internally regulated, and works well with a Q-Jet.
Old Aug 21, 2013 | 08:37 PM
Mr Nick's Avatar
Originally Posted by pbarney
and not too loud.
In tank is the way to go for keeping noise down. Also generally more expensive and slightly harder to install.
I can only hear my pump running if I stick my head under the rear bumper with key on engine off.
ah64pilot
Apr 9, 2012 02:55 PM
big mean
Dec 11, 2009 06:44 AM
oldjunk
Sep 23, 2009 04:34 AM
ozzyolds
Aug 26, 2008 12:56 PM
Sixoh
Dec 18, 2006 02:07 PM
