Electric Fuel Pump Placement
Old Dec 18, 2006 | 08:50 AM
Sixoh's Avatar
...well the directions say away from heat sources and moving parts, and lower than the tank. That sounds easy.....but....this is a '62 Olds, with the tank mounted in front of the trunk.
Where do you guys usually find as a good location for the electric pump?
Old Dec 18, 2006 | 09:10 AM
texasred's Avatar
Tom Servo's Stunt Double
On the frame as close to the tank as possible. Electric fuel pumps are for "pushing" the fuel, not "pulling" it like a mechanical.
C.J.
Old Dec 18, 2006 | 10:22 AM
Sixoh's Avatar
I'm thinking of mounting it on the right rear inside of the frame, just after it kicks up over the rear wheel. We'll see how that goes. It's just the plumbing I'm worried about!
Old Dec 18, 2006 | 02:07 PM
texasred's Avatar
Just keep the fuel line away from the exhaust pipe and enough slack to clear differential travel and you'll do fine.
C.J.
cameron_zank
Ninety-Eight
Nov 3, 2014 12:32 PM
ah64pilot
Apr 9, 2012 02:55 PM
big mean
Dec 11, 2009 06:44 AM
oldjunk
Sep 23, 2009 04:34 AM
ozzyolds
Aug 26, 2008 12:56 PM
