Electric Fuel Pump Placement
Old December 18th, 2006, 08:50 AM
Sixoh's Avatar
...well the directions say away from heat sources and moving parts, and lower than the tank. That sounds easy.....but....this is a '62 Olds, with the tank mounted in front of the trunk.
Where do you guys usually find as a good location for the electric pump?
Sixoh is offline
Old December 18th, 2006, 09:10 AM
Tom Servo's Stunt Double
texasred's Avatar
On the frame as close to the tank as possible. Electric fuel pumps are for "pushing" the fuel, not "pulling" it like a mechanical.
C.J.
texasred is offline
Old December 18th, 2006, 10:22 AM
Sixoh's Avatar
I'm thinking of mounting it on the right rear inside of the frame, just after it kicks up over the rear wheel. We'll see how that goes. It's just the plumbing I'm worried about!
Sixoh is offline
Old December 18th, 2006, 02:07 PM
texasred's Avatar
Just keep the fuel line away from the exhaust pipe and enough slack to clear differential travel and you'll do fine.
C.J.
texasred is offline
cameron_zank
Ninety-Eight
November 3rd, 2014 12:32 PM
ah64pilot
April 9th, 2012 02:55 PM
big mean
December 11th, 2009 06:44 AM
oldjunk
September 23rd, 2009 04:34 AM
ozzyolds
August 26th, 2008 12:56 PM
Quick Reply: Electric Fuel Pump Placement
