When I turn on the heater in my 70-442, it blows warm,
Old September 14th, 2017, 05:44 PM
capstoneclub's Avatar
but within 10 seconds or so the air gets cooler. Any idea on the issue?
capstoneclub is offline
Old September 14th, 2017, 05:46 PM
Is it an AC or non AC car?
Allan R is offline
Old September 14th, 2017, 09:28 PM
A/C car
70-442
Old September 14th, 2017, 09:32 PM
svnt442's Avatar
Originally Posted by capstoneclub
70-442
That doesn't help as 442's came with or without A/C.
My guess is that you are low on coolant if the heat is disappearing that quickly. There could also be an issue with the heater control valve (if the car came with A/C).
svnt442 is offline
Old September 15th, 2017, 05:07 AM
Gary
VC455's Avatar
The root cause is low coolant flow through the heater core.
You were asked about A/C or non-A/C because A/C has an extra component in the system--a shutoff valve on the intake manifold--that may fail.
VC455 is offline
Old September 15th, 2017, 06:12 PM
Coolant level is full
I assume it must be the valve. Where is this valve located? On the passenger side rear area of the intake?
Old September 16th, 2017, 07:30 AM
Gary
VC455's Avatar
...is this valve located...(o)n the passenger side rear area of the intake?
Correct.
VC455 is offline
Old September 16th, 2017, 07:57 AM
texxas's Avatar
By the way guys he answered the a/c question in the title of his first post after the question was asked.
texxas is offline
Old September 16th, 2017, 10:49 AM
Allan R is offline
Old September 16th, 2017, 11:37 PM
Thanks Alan
I will give it a shot
ankerclanker
October 30th, 2016 10:17 AM
fritz442
October 14th, 2012 02:08 PM
aaronlife
June 21st, 2010 04:50 PM
Gert3116
January 13th, 2008 11:48 AM
beanship
Bravada
July 10th, 2007 12:36 PM
Quick Reply: When I turn on the heater in my 70-442, it blows warm,
