Fuse blows when selecting turn signal
Old Oct 30, 2016 | 06:58 AM
ankerclanker's Avatar
I am having basically the same problem with my 65 brake lights. have replaced brake light switch. when moving the turn signal switch down for a left turn indicator, my brake lights work just fine, when moving up for a right turn indicator, fuse blows, so with the information I have gleaned from this thread, I am going to guess that my turn signal switch is bad. Good ASSumption?
ted
Old Oct 30, 2016 | 07:55 AM
Same problem only different, I moved your post to its own thread. I've found that sometimes the turn switch shorts to the turn signal lever.
Old Oct 30, 2016 | 10:17 AM
m371961's Avatar
I would not assume switch is bad without checking wiring first. Any recent work done that may have pinched a wire?
costpenn
Jun 24, 2015 10:38 PM
Colpage1
Jun 22, 2015 08:19 PM
1FSTLS1
Jul 1, 2008 12:12 PM
fahaka
May 29, 2007 10:15 AM
