Help on selecting valve terain
Old Jul 1, 2008 | 11:34 AM
1FSTLS1's Avatar
Building 455BB with stock J heads. I got my heads and valve springs but need opinions on what to do w rocker arms. Cam specks are as follows:
CRNK DEG
Duration at .o5 in
Intake Rocker ration 1.6 in
Lash 22 24 25 hyd
Exhaust Rocker Ratio 1.6
Lash 23 24 25 hyd in
Install can on * * Below Cyl# 1
Intake & Exhaust
Lobe Seperation= 110 CAM DEG
Valve overlap= 8 Crank DEG
Intake
Valve open = 4.2 BTDC
* Centerline 108 ATDC
Valve Close= 41.2 ABDC
Duration 225.5 Crank Deg
Lobe lift= .30343 IN
Valve lift .48548 IN
lobe are= 23.87 IN * DEG
Exhaust
Valve open = 47.8 BBDC
Centerline 108 ATDC
Valve close = 3.8 ATDC
Duration 231.5 Crank DEG
lobe lift .30185 IN
Valve lift ..48296 IN
lobe area= 24.94IN * DEG
Old Jul 1, 2008 | 12:12 PM
That's not a terribly radical cam. Stock valvetrain will work fine, though you can never go wrong with the Harlan Sharp rollers.
1970_442
Aug 11, 2018 07:50 AM
Mike H.
Brakes/Hydraulic Systems
Mar 7, 2013 10:48 AM
jpc647
Oct 12, 2012 03:11 PM
JRios
Dec 13, 2010 11:13 PM
fahaka
May 29, 2007 10:15 AM
