Wheel stud stripped
Old Feb 8, 2021 | 04:24 AM
Sven_Olds69's Avatar
Wheel stud stripped
Hi,
On my 1969 Olds Cutlass S (V8, 350) a coulple of wheel studs got damaged.
I am not sure how to fix it. There is no room to tap them out.
Should I just get a new rotor hub assembly?
Thanks for your advise.
wheel stud damage
Old Feb 8, 2021 | 04:58 AM
Remove the rotor and hub from the spindle. You need to do this on a press anyway. Also, be sure you get the correct lugs for those two-part rotors. I suspect most places will have them listed incorrectly.
Old Feb 8, 2021 | 05:09 AM
Post70's Avatar
It wouldn't hurt to scribe a line across the two before you take them apart. It's possible the factory balanced them as an assembly.
Old Feb 8, 2021 | 05:12 AM
OK, but why even separate them? The OP is only changing a couple of the studs.
Old Feb 8, 2021 | 07:53 AM
Sugar Bear's Avatar
Are the studs swedged? Is there a special tool or cutter to use before removing them to prevent damaging/enlarging the holes in the hub or can they just be pressed in/out?
Old Feb 8, 2021 | 02:39 PM
Yellowstatue's Avatar
I don't think there is enough room to drive the studs out with it being attached to the rotor.
Old Feb 8, 2021 | 02:51 PM
You don't want to "drive" anything out on the car, period. Even if there were room, wailing on the stud with a two pound sledge is guaranteed to bend the hub, or worse. The backside of the rotor needs to be properly supported in a press. It IS possible to R&R the studs on the rear axle flanges. There's a special "C-clamp" tool to do it without bending anything.
Old Feb 8, 2021 | 07:16 PM
oldsmobilejim's Avatar
What year, 1969 had a two piece front rotor?
See I learn something today, alright!!!!!!!!!!
Old Feb 9, 2021 | 07:27 AM
rob1960's Avatar
Those rotors are bolted together from the back side, you have to unbolt the rotor from the hub & then press out the studs of the hub. The studs don't go through the rotor on this type.
Old Feb 9, 2021 | 12:43 PM
'67, '68 & '69 had two piece rotors, but '69 was the first year for one piston calipers.
Old Feb 10, 2021 | 04:50 AM
Bfg's Avatar
Bfg
Would a thread chaser clean the threads?
Old Feb 14, 2021 | 03:36 PM
FN723's Avatar
Of course you have to remove the hub but I've taken those out and replaced them with just a hammer. They come out easier than you think. As long as you set the hub on something solid you shouldn't damage it. While you are at it I would replace all of them. The one that was broken was probably weakened by some tire guy over torquing the lug nuts so they are probably all weakened. .
ROCKETMAN269V
Apr 27, 2024 07:25 AM
ROCKETMAN269V
Rvsmith5
Wheels and Tires
Apr 6, 2020 12:11 PM
Mlunsford33
Wheels and Tires
Jul 4, 2019 12:28 PM
The Stickman
Mar 16, 2010 07:34 PM
