What is this part?
It's a Distributor Vacuum Control Switch.
It diverts full vacuum (instead of ported vacuum) to your distributor vacuum advance at certain times in order to reduce oxides of nitrogen.
Basically, it sets the timing correctly on rare occasions, so that it can be set way too retarded the rest of the time in order to reduce emissions.
You don't need it if you set your advance properly (that is: not according to the factory settings) in the first place.
Don't throw it out, though - that's what everyone else did in the '70s, and there are a few all-out restorers out there who are looking for them.
You might want to read this thread on electric chokes:
https://classicoldsmobile.com/forums...ke-wiring.html
Actually, the green/white wire is fed from the 20A backup lamp fuse. 20A is what GM used on factory electric choke setups. I would still use an oil pressure switch to prevent the choke from heating up prematurely with the engine not running.
Dead Reckon
March 25th, 2014 01:02 PM
IZAOLDS
August 9th, 2010 08:36 AM
Texas Jim
Ninety-Eight
17
December 30th, 2009 06:28 PM
