weatherstrip adhesive removal
Old May 2, 2014 | 07:24 AM
chip-powell's Avatar
Does anyone know how to remove weatherstripping adhesive without damaging the paint?
Whomever replaced the trunk weatherstripping on my cutlass before I bought it did a very sloppy job of applying the glue. They also used the incorrect weatherstriping (but that is beside the point). I want to replace it, but I did not want to start until a had a safer way to remove the adhesive without taking the paint up also.
Old May 2, 2014 | 07:38 AM
F-85 4-4-2's Avatar
3M Adhesive Remover.
Old May 2, 2014 | 08:18 AM
3M remover wont damage the paint? I've heard good and bad things about it, so I was holding off.
Old May 2, 2014 | 08:47 AM
dc2x4drvr's Avatar
Won't harm paint.
Old May 2, 2014 | 10:35 AM
Thanks. I'll give it a try as soon as the new weatherstripping comes through the mail.
Old May 2, 2014 | 11:38 AM
rocketraider's Avatar
Oldsdruid
Get a set of these or something similar http://www.harborfreight.com/4-piece...set-95832.html.
Used them and the 3M stuff to get glue residue off the gray wagon's door w/strips. 3M also makes a weatherstrip release agent that helps.
Old May 2, 2014 | 04:10 PM
501Paratrooper's Avatar
I used this stuff, worked really good.
http://www.marineformula.com/
Old May 6, 2014 | 05:00 PM
852's Avatar
852
I used goo gone worked perfect and you can find it everywhere. Aerosol can worked the best.
Old May 6, 2014 | 07:32 PM
Lady72nRob71's Avatar
A CD cut into small pieces make for plastic scrapers that can remove big chunks and be easy on paint. GooGone works for lighter coats.
Oldracerjones
Feb 12, 2014 06:54 AM
costpenn
Body work
Apr 3, 2012 10:27 AM
atkinsom
Care and Appearance
Aug 12, 2011 07:58 AM
mike's88
Oct 20, 2010 08:47 AM
72rocket
Nov 12, 2009 05:55 PM
