Washer Tank Bolt Size
Can someone give me an idea of the correct bolt size for the washer jar for a 70 442.
I see in the assembly manual that .312 diameter hole or roughly 5/16th, and screw part number 9419380.
I assume it is 3/8 but how long?
For the 1970 washer jar, Lansing used three 3/16" x 3/4" sheet-metal-type screws with 3/8" hex head, black oxide. Not sure what other assembly plants used.
Perhaps the 0.312" dia hole was a clearance hole in the inner fender.
