Washer Tank Bolt Size
Old Jul 26, 2021 | 09:08 PM
Troys Toy 70's Avatar
Once Olds Always Olds
Can someone give me an idea of the correct bolt size for the washer jar for a 70 442.
I see in the assembly manual that .312 diameter hole or roughly 5/16th, and screw part number 9419380.
I assume it is 3/8 but how long?
Old Jul 27, 2021 | 04:55 AM
72455's Avatar
1972 U code Supreme
If the hole is 5/16 then a 3/8 bolt will be too big. So the bolt either has to be 1/4 or 5/16..
Old Jul 27, 2021 | 09:11 AM
VC455's Avatar
Barely Registered
For the 1970 washer jar, Lansing used three 3/16" x 3/4" sheet-metal-type screws with 3/8" hex head, black oxide. Not sure what other assembly plants used.
Perhaps the 0.312" dia hole was a clearance hole in the inner fender.
Old Jul 27, 2021 | 09:31 AM
nicks1966's Avatar
Old Jul 27, 2021 | 10:10 AM
VC455's Avatar
Barely Registered
That be the one!
Old Jul 27, 2021 | 12:05 PM
RandyS's Avatar
Check your nearby ACE Hardware, they carry a huge assortment of hardware.
Old Jul 27, 2021 | 02:39 PM
Perfect, thanks everyone!
Yes the .312 diameter hole is in the wheel well. I should have mentioned that.
Old Jul 27, 2021 | 06:44 PM
70Post's Avatar
Originally Posted by nicks1966
These are the correct sized screws....1/4" (#14) threads. You could probably go w/a 5/8" thread length if you though the 3/4" was a bit too long.
Reese Neis
Mar 24, 2021 02:38 PM
BobPlouhar
Jan 5, 2021 08:26 AM
NotDads442
Dec 1, 2018 06:51 PM
73aussie455
Nov 15, 2014 04:38 AM
charlierogers
Mar 10, 2013 06:36 PM
