Want more horsepower
Old November 20th, 2009, 04:52 AM
ELECMAN's Avatar
I have a 72 olds 442 the engine is 455 with a F block and G heads the carb is an edelbrock # ending with 251 I want to leave the stock look but give it more horse power and have a set of flow masters and a 323 posi rear with a th400 tranny with a slap shifter any input would be help full
ELECMAN is offline
Old November 20th, 2009, 05:52 AM
You can put an aftermarket cam in it. You could also put higher compression pistons in it. If you don't want to do mechanical engine work then you could always add W/Z manifolds on it (or a set of headers if you don't mind going non original). Don't forget you can also add an aftermarket intake manifold and paint it to match the engine color.
Olds64 is online now
Old November 20th, 2009, 07:26 AM
citcapp's Avatar
Its all about the money when you seek more HP. As said above hotter cam, rework the heads with bigger valves, higher compression pistons, adjustable valve train, intake manifolds, etc. There are a number of build threads in the big block forum with great detail. Take a look there then narrow you questions down and think about how much money you are willing to spend. We can go from there
citcapp is offline
70cutty
May 23rd, 2015 01:25 PM
golow1
April 24th, 2014 09:11 AM
rhett838
April 5th, 2012 05:10 PM
Ranzan
January 18th, 2010 10:13 PM
mutzi
April 28th, 2009 06:37 AM
Quick Reply: Want more horsepower
