W-31 Drag Race ET's
Old July 6th, 2021, 01:21 PM
  #41
Jeff Stout's Avatar
Originally Posted by Indy Guy
Here are some time slips from the early 70’s when my 70 W31 ran at US 30 Dragstrip.
Are you a member on Facebook US30 page? If not they would love to see this on their page. I have posted alot on there as that was my home track since 1967 until closing.
Jeff Stout is offline
Old July 8th, 2021, 12:57 AM
  #42
69CSHC's Avatar
August 1968 HOT ROD MAGAZINE wrung out a 1968 F85 with a W31 350 installed. Including force air system and highway patrol police apprehender equipment. Originally 3330 LBS including spare tire. After 1000 break in miles they took her to Irwingdale Raceway. Tested from almost stock (except for 1 7/8s full length headers), to slicks, carb, timing, and exhaust play.
Headers with closed exhaust 4 speed manual (M21), 3.91 rear limited slip, no air element. Launched at 5000 RPM shifted at 6000 RPM. Stock tires. 14.08 @ 98.90 MPH
As above plus opening up the exhaust, new spark plugs, and slicks (27in tall 6 5/8in wide). 38 degrees total advance. Same launch and shift points. 13.61 @ 103.21 MPH
Now exhaust dropped, 4.66 gear swap, and 3500 RPM launch otherwise all the above. 13.40 @ 104.04 MPH
Finally, fine tuning (carb adjustments), back to 5000 RPM launch, with bigger slicks (29in tall 7in wide), otherwise same as all the above. At this point the Olds was classified E/S class. And put down 230 HP to the wheels.
Best run 13.20 @ 105.75 MPH
For more details http://wildaboutcarsonline.com/membe...art_II_1-3.pdf keep in mind this is the 2nd part to a 3 part series.
69CSHC is offline
Old August 1st, 2021, 04:50 PM
  #43
Stefano's Avatar
Here is a show board from one of the W-31s discussed here. I thought these ets were very quick.
Stefano is offline
Old August 1st, 2021, 06:28 PM
  #44
Chevy budget Olds powered
coppercutlass's Avatar
Not out of line with a stocker for today's standards. I think Sam Murray is running low 11's with his 350 powered stocker. I guess it depends on when the E/T was set wether or not it pegs the BS meter.
coppercutlass is offline
no1oldsfan
July 3rd, 2021 12:11 AM
4-Speed
Cars Wanted
January 17th, 2020 01:45 AM
scottv442
December 24th, 2017 09:59 AM
shiftbyear
November 25th, 2017 07:05 AM
WEBBISH
March 4th, 2009 11:11 AM
Quick Reply: W-31 Drag Race ET's
