Vavle rotater info??
can some one post up some photos of the valve rotators Olds use . I have a set of 70 E heads and both sets of vales look the same the only difference in the retainers I can see from my D heads is a the portion seems to sit down on the valve about 3/8 of a inch . I will add photos if I can get them to upload.
so I have read that the Exhaust valves have rotators mine look to be the same on each head could not get a good angle and but the only thing I see different than the D head is a portion of the retainer sits over the valve stem and down in the spring Thanks
Depends on what your plans are for the heads.
If you are looking for performance, change to the ones like on your "D" heads along with the valve springs.
If just a daily driver, street cruiser , use what is there and run it.
Gene
Gene
griz_83ho
June 2nd, 2013 02:38 PM
sx455raidercelticfan
August 1st, 2010 08:03 PM
