Vavle rotater info??
Old May 15, 2015 | 04:42 AM
firefrost gold's Avatar
can some one post up some photos of the valve rotators Olds use . I have a set of 70 E heads and both sets of vales look the same the only difference in the retainers I can see from my D heads is a the portion seems to sit down on the valve about 3/8 of a inch . I will add photos if I can get them to upload.
Old May 15, 2015 | 05:02 AM
so I have read that the Exhaust valves have rotators mine look to be the same on each head could not get a good angle and but the only thing I see different than the D head is a portion of the retainer sits over the valve stem and down in the spring Thanks
Old May 15, 2015 | 05:16 AM
On these heads, the intakes have rotators, the exhausts do not:
Old May 15, 2015 | 05:17 AM
Originally Posted by firefrost gold
... the only thing I see different than the D head is a portion of the retainer sits over the valve stem and down in the spring
Both of those valves have rotators.
Old May 15, 2015 | 08:18 AM
That's what I was thinking. I know it's a toro 455 that they came off of I wonder what's the rule for single vs dual rotators ?
Old May 16, 2015 | 09:21 AM
64Rocket's Avatar
Depends on what your plans are for the heads.
If you are looking for performance, change to the ones like on your "D" heads along with the valve springs.
If just a daily driver, street cruiser , use what is there and run it.
Gene
Old May 16, 2015 | 04:47 PM
Trying to learn more about how stuff works. I picked the engine up it was locked up from sitting . Tore it down time to find a machine shop
griz_83ho
Jun 2, 2013 02:38 PM
sx455raidercelticfan
Aug 1, 2010 08:03 PM
viper771
May 31, 2010 12:40 PM
Keener
Apr 24, 2010 10:43 AM
Toro68
Sep 28, 2008 04:29 PM
