valvetrain
Old August 8th, 2011, 04:36 PM
64oldsguy's Avatar
Cool valvetrain
64 Olds 330, #1 head rocker arm shaft. Installed new cam, lifters and valve springs. If the lifters are properly preloaded, what else can make so much valvetrain noise(like lifter noise)
64oldsguy is offline
Old August 9th, 2011, 12:29 AM
64Rocket's Avatar
What is your oil pressure?
Is the inside of the engine very clean?
How much preload do you have?
What lifters did you use?
Gene
64Rocket is offline
Old August 9th, 2011, 02:23 AM
64oldsguy's Avatar
Hey Gene, thanks for the response. This is driving me bonkers. engine runs 30-40 psi hot. Looks like plenty of oil pumping through the pushrods. Engine is clean inside. measuring .040-.060 preload on comp lifters. Thats on #1 cyl. tdc. Should I check all the cylinders? Comp say's piston travel on the lifter is up to .120" but thats getting close to no pump up.
Old August 11th, 2011, 10:21 PM
64Rocket's Avatar
Did you receive my PM?
Gene
64Rocket is offline
Old August 12th, 2011, 02:25 AM
64oldsguy's Avatar
No I did not
Roger
Mark71
November 4th, 2011 09:33 PM
64oldsguy
August 7th, 2011 08:40 PM
70cutty
August 15th, 2008 09:45 PM
SPEEDROCKET
December 18th, 2007 05:58 PM
davy5
April 24th, 2007 10:00 AM
Quick Reply: valvetrain
