noisy valvetrain
I have a 64 Olds cutlass with the 330 high compression. Just installed a new cam and lifter kit, plus new valve springs from Mondello. Little bigger cam than stock. Put it all together and walla, noisy valve train that was not there before. Called Mondello and said to buy new adj. rocker arms. Friend of mine said with some new bigger cams, you may experience more than normal valvetrain noise. It's not like the lifter tick noise I had which is why I did a new cam and lifters. It's consistent throughout both sides front to rear. Any ideas? The valve springs Mondello sold me are much stiffer and taller than the stock ones. I called Mondello and they assured me these are the correct springs.
valvetrain noise
just pulled my valve covers off and ran engine. my 330 oils through the push rods and getting plenty of oil to the rocker arms.
So your Pushrods are hollow, 394's are solid and I guess that's the reason the Rocker Arm Shaft is designed with oilers like they do, and get their lubrication from the under side of the Shaft.
Which is it, bridge or shaft? Most 1964 330s came with #1 heads and shaft rockers, but late production motors got #2 heads and bridge mount rockers.
In any case, does this cam have a reduced base circle? If so, you either need adjustable rockers or longer pushrods to make up the difference. Otherwise, you'll get noise.
valvetrain
Hey Joe, it's been awhile since our last thread. I'm still looking to rid myself of valvetrain noise. I think I have exhausted all ideas from friends and others in the hobby. After replacing my cam and lifters with one from comp, I purchased longer pushrods so I can shim down to adjust the rocker arm shaft. I'm about .060 preload on lifters which puts me in the middle of piston travel and still noise. Is there something else I'm missing? Are there any secrets with the rocker arm shaft. I measured the base circle, it is smaller so with longer pushrods and proper preload it should be quiet,right??? any ideas would be helpful
thanks
thanks
