trying to figure out what rear gear would be good
Old Sep 17, 2009 | 12:04 PM
chris83's Avatar
i have a 1974 olds cutlass 442 with a 455 .40 over big block out of a 1968 442 the motor is 10.1 comp trw forged racing heads a huge comp cam extreme energy 284 cam kit with roller 1.7 rockers double roller timing chain with the big valve c racing heads i have a built turbo 400 trans and a eaton 4.10 posi so idk since the 455 is making a ton of power and torque maybe a higher gear ratio like 3.73 or 3.55 would be better the car is a street car and i love the way it launches with the 4.10 but rpms get really high after 45 mph so looking for best setup and trying not to lose all my launch even though my 3000 stall should keep it launching hard so any help would be appreciated
Old Sep 17, 2009 | 12:16 PM
svnt442's Avatar
What tire are you running? You can effectively change your gear ratio by going with a larger diameter tire. Much cheaper and easier.
Old Sep 17, 2009 | 02:48 PM
citcapp's Avatar
I am running 3:08's in my 57 Olds with a built 455 and with a 2200 stall convertor it launches real had. Cruises at 2100 rpm at 65 and it weighs more then yours
Old Sep 17, 2009 | 06:08 PM
BIGJERR's Avatar
I bleed Oldsmobile
Iam running a 3.73 and a 28 inch tall tire..........
fast442
Jan 14, 2015 08:56 PM
lesliek30
Feb 2, 2012 11:59 AM
CutlassLegend
Oct 3, 2011 03:37 PM
Deacon
Aug 28, 2009 08:02 PM
foo
Apr 3, 2009 12:10 PM
