Trouble getting car started after engine rebuild
Hello all. I recently just re-installed my 455 in my cutlass. I am having trouble keeping it running. I turn it over and it fires and then dies. If it were to have the constant power of the starter it seems like it would run. I thought it was fuel related. unhooked the fuel pump to see if it was spitting fuel and it is working properly. Could this be an electrical problem? I bought a new ignition coil and it did not come with that small condenser that was on my old one. Maybe its that? The only other modification I did was a C heads and Roller Rockers. Also with the Starter solenoid. One of the posts isn't used correct? Any ideas?
So you are running a stock points ditributor? Have you set the point dwell? Did you connect the black wire from the points to the NEGATIVE on the coil? Are all vacuum ports connected or plugged? What did you set the timing at?
The problem in the post refered to can occur in point sysytems or HEI. Try what oldscut says. Just don't run it long with this connected, shortens point life.
Both small posts on the starter solenoid are used. One activates the solonoid coil, voltage is applied with key turned to start. Off the top of my head I don't remember which is which. The other supplies 12 volts to the coil positive when the starter operates. When the key goes back to the run position, voltage at coil positive term is btw. 6 and 9 volts.
Hmmm. I thought more people knew how to hot-wire old cars. Guess thats just another lost art!!
![Roll Eyes (Sarcastic)](https://classicoldsmobile.com/forums/images/smilies/rolleyes.gif)
Well she lives. When installing the starter I had both the Purple and Yellow wires on the S post on the starter solenoid. The weird thing is, that's how it was when I pulled the engine. The last time I had then engine out was two years ago. It had been running that way for that last two years. Any ideas?
I agree the car gods smiled on you, leave it be. Make sure your coil+ feed wire from the ignition still has the resistor wire on it. You should read somewhere around 9.5v with the car running. Good job!
jensenracing77
November 6th, 2022 09:52 PM
SD72cutlass
December 7th, 2014 04:47 PM
oldzy
September 12th, 2010 10:32 AM
CreekBandDad
July 15th, 2007 02:01 PM
