Transmission fluid coming out of filler tube
Old Jan 31, 2016 | 12:38 PM
67Rocket's Avatar
Before parking my car for a few weeks, I checked all fluid levels and every thing checked out o.k. Today I noticed a large puddle of trans. fluid under the car and traced it back to coming out of the top of the filler tube. The trans was not over filled so why would fluid come out of the top of the filler tube? The trans is a T H 400. Thanks!
Old Jan 31, 2016 | 01:30 PM
toymobile's Avatar
The vent tube may be blocked, You can reach it from the bottom, (it's right in the middle of the case up front just as the bell housing start up to clear the converter)Plastic tube about 1/8in ID, doesn't take much to block it off, wasp love it. Good luck
Johnny
Old Jan 31, 2016 | 04:41 PM
67Rocket's Avatar
Thanks I will check it. I've had several T H 400 trans. for a long time and never had this problem. I have had them leak where the tube goes into the trans. case but nothing like this. Thanks to all for any suggestions.
Old Feb 1, 2016 | 05:09 AM
RetroRanger's Avatar
72 Olds CS
Converter drain back overfilling the pan?
pmathews
Sep 11, 2015 06:25 PM
t42
Oct 28, 2012 11:43 PM
yopester
Nov 18, 2010 09:46 PM
cfair
Brakes/Hydraulic Systems
Jun 8, 2009 12:37 AM
scrappie
Apr 9, 2008 05:17 PM
