Tilt Steering
73-77 A-Body is the same except for the arm @ the bottom where the trans rod connects. The 69-72 arm is curved and the 73-77 is straight. Some of the 73-77 columns have the headlight dimmer switch built into the turn signal lever,those are different. I think the curved and straight arms interchange. There were more 73-77 cars with tilt than 69-72 but they are getting hard to find. Ron was correct,all 69-72 GM A-Body columns interchange. If you can find a 69-72 Pontiac Gran Prix,a majority of them had tilt columns and they were almost always F/S.
when swapping a 69-72 a-body tilt wheel from a standard wheel remember that the ingation rod is opposite on tilt.There is need need to cut the harmess,just flip the ignation switch upside down and reverse the connectors.This is only down when converting from a standard to a tilt.
ELECMAN
January 22nd, 2012 01:49 PM
