Tilt Steering
Old Mar 2, 2012 | 10:42 AM
rcrac3r's Avatar
Tilt Steering
Did the 72 Cutlass ever have tilt steering as an option?
Old Mar 2, 2012 | 10:47 AM
GAOldsman's Avatar
"Car"mudgeon
Yes it sure did.
Old Mar 2, 2012 | 10:51 AM
GAOldsman's Avatar
"Car"mudgeon
Option N33 Tilt-Away (had to have anything other than the standard 3 on the tree unless W39 was ordered which was the Hurst 3-speed floor shifter) $44.00 option
Old Mar 2, 2012 | 10:53 AM
rcrac3r's Avatar
Great! IF possible I'm hoping to find a 72 tilt steering column somewhere to replace the stock column mine has.
Old Mar 2, 2012 | 10:59 AM
oldspackrat's Avatar
I have a column shift tilt steering column. If you wanna floor shift,be prepared for sticker shock. They are pretty expensive. Pm me or call for more info.
Thanks.
Scott
c. 317-727-7041
Old Mar 2, 2012 | 11:38 AM
droptopron's Avatar
delete
Also, please note that '69-'72 should be the same & I believe they are the same for other A-Bodies.
Old Mar 2, 2012 | 12:12 PM
66-3X2 442's Avatar
73-77 A-Body is the same except for the arm @ the bottom where the trans rod connects. The 69-72 arm is curved and the 73-77 is straight. Some of the 73-77 columns have the headlight dimmer switch built into the turn signal lever,those are different. I think the curved and straight arms interchange. There were more 73-77 cars with tilt than 69-72 but they are getting hard to find. Ron was correct,all 69-72 GM A-Body columns interchange. If you can find a 69-72 Pontiac Gran Prix,a majority of them had tilt columns and they were almost always F/S.
Old Mar 2, 2012 | 12:45 PM
Highwayman's Avatar
National Parts Depot has remanufactured tilt columns in their Chevelle catalog for $429.95
Good way to gain some head room.
Old Mar 5, 2012 | 05:04 PM
ELECMAN's Avatar
when swapping a 69-72 a-body tilt wheel from a standard wheel remember that the ingation rod is opposite on tilt.There is need need to cut the harmess,just flip the ignation switch upside down and reverse the connectors.This is only down when converting from a standard to a tilt.
montvaleplace
Tech Editor's Desk
Jul 20, 2012 06:45 PM
ELECMAN
Jan 22, 2012 01:49 PM
1968Cutlassfallbrook
Apr 7, 2011 05:06 PM
cutlasspeg
Aug 14, 2004 02:32 PM
