The Tach in the Middle spot on a 69 Cutlass?
Is there any reason not to put the tachometer in the middle?
I just sent my three gauges - speedminder speedo, rallye cluster, and tic toc tach to John at redline to be serviced as needed.
Has anyone on here ever swapped the location of the tach and the speedometer. The right hand location kinda sucks as far as visibility and I'm thinking that I'd rather have the tach/clock in the middle.
Will the speedo cable likely reach easy enough to the right hand location?
The speedo cable may reach but I'm not sure you'll get it to connect. You may have to put another hole in the firewall so it lines up.
You're also going to have problems getting your wiring harness to reach
BTW, I'm 6'-1" and I have no problem seeing the tach
I'm only 5'10" but the right hand side of the wheel obstructs the right gauge location. I think it would be awesome in the middle.
RAMBOW
May 3rd, 2022 04:25 PM
Thuffner3
December 11th, 2007 07:38 PM
