Tach Connection
Tach Connection
I bought an after market tach guage for my 72 cutlass 455 ci engine .It fits in the clock spot the problem I'm having is where does the tach lead connect to.I have a pink,Brown,and Black wire come out of the distributor going to the top of the cap.The black wire fell out on the top of the cap dont know where that goes.but before it fell out I put the wire coming out of the tach to the tach slot on the cap got no reading what do I do from here Thanks.
Are you running an HEI? If so it clearly states "tach" on the cap.
If you got no reading then you probably have a bad tach.
Most aftermarket tachs are white, green, red and black for the wires.
Red to SWITCHED power, black to ground, white to the dash lights and green to the coil.
The easy rule of thumb is that the tach connects to the same side of the coil as the distributor. The distributor SHOULD be connected to the negative side of the coil, but the coil may be hooked up backwards.
maybe i'm wrong, but don't they need like oil and wather temp meter the ignitionkey 12volt and a ground to work?
ground- 12volts - and sender?
if mounted corectly ad power source you can trie the + or - side of the coil. one should work.
OK connected the wire from the tach to the tach port on the distrubator.the problem I'm having is at idle it reads about 2500 rpm at a stand still shift the car in drive still the same thing.started to drive the car and the tach came down to 1500 rpm and started to increase when I stepped on the gas.called the tech that supplied the tach and said it cant be the tach because the tach gives a polsating 12 volts.he said it could be my points on the cap does that sound right.
That doesn't make any sense. First of all with an HEI there are no points. It's all done electronically so if the car is running then the module is good. Second there could be something wrong with the tach. Is that the tach you are using in that pic?
Make sure the case is properly grounded. It usually grounds through one of the mounting screws. Just make sure they are all tight.
Other than that I would try and test it on another running V8 and see what it does.
Note that the ground should be through a metal ground strap on the plastic dash insert. Be sure these are in place. Alternately, use a temporary ground wire.
RAMBOW
May 3, 2022 04:25 PM
