Steering wheel lock plate issues
Old Jun 22, 2016 | 07:41 PM
Kt 74's Avatar
I have a 1967 convertible cutlass that needed a signal switch replaced. Upon doing so , I now cannot get the lock plate attached to steering cover to turn and lock in place. What am I doing wrong?
Old Jun 22, 2016 | 08:02 PM
RROLDSX's Avatar
There is a spring behind the plate and the plate is held in place with a wire C clip. The only way I was able to put the clip back in is to use a spacer the same inside diameter as the outside diameter of the steering shaft. Use the nut to compress the spacer down on the plate while sliding the retaining flip into the groove. Hope I explained this clearly. The CSM will probably have a better procedure.
Old Jun 23, 2016 | 06:21 AM
A 1967 steering column doesn't have a "lock plate", since locking steering columns didn't appear until the 1969 model year. Perhaps a photo of what you are talking about will help us give you the correct answer.
Old Jun 23, 2016 | 08:09 AM
Kt 74's Avatar
The part at the bottom is what I'm having trouble with. I did notice the small c clip that was still on . This may be my problem
goldie442
Aug 21, 2015 11:01 AM
benjamin247
Oct 1, 2014 07:23 PM
Maverick
Apr 22, 2014 05:04 AM
randomarrival
Dec 22, 2012 12:28 PM
g77rvd
Mar 18, 2011 11:45 PM
