stalling noob
Old Feb 18, 2013 | 02:58 PM
lowkey235's Avatar
stalling noob
I am new to the hobby, I recently bought a 1966 toronado. I refreshed the quadrajet that came with it and now I have a problem with stalling when I get off the throttle from WOT...any suggestions ? it is a 425 the previous owner put hei distibuter on, what should I check first? previous owner also has a single exhaust set up, can that be part of the problem?
Last edited by lowkey235; Feb 18, 2013 at 03:00 PM. Reason: additional information
Old Feb 18, 2013 | 03:07 PM
Octania's Avatar
The last thing fixed is where you look first...
Carb probably needs some adjustments such as secondary air valve spring wrap, or the vacuum break is missing or inoperative.
oh... OFF the throttle FROM wide open...
Hmmmm.... that is weird... idle set too low?
How does one even have single xst on a '66 Toro?
Old Feb 18, 2013 | 03:09 PM
tru-blue 442's Avatar
Old School Olds
Did you give the body of the carb
a good 12 hour soak in say Berryman's
carb dip?
Old Feb 18, 2013 | 03:37 PM
lowkey235's Avatar
I dipped and cleaned the carb and set specs to standard as in the adjustment tables that came with rebuild kit. I think last owner was to cheap to spring for proper muffler. I have proper exhaust ordered. When I set idle I set with car in drive? sorry but I'am new to carbs..
Old Feb 18, 2013 | 05:03 PM
rocketraider's Avatar
Oldsdruid
68-70 single exhaust Toronado mufflers are a lot easier and cheaper to find than the correct double-in/double-out 66-70 dual exhaust unit.
Does this carb have a dashpot on the throttle arm? If so, it may need adjustment to keep the throttle plates from closing off too far too quickly. Spec should have been in the rebuild kit instructions. If not, let us know- many of us have 1966 CSMs.
Old Feb 19, 2013 | 04:13 PM
lowkey235's Avatar
There is a dash pot on the throttle side,I can't find the proper adjustments...I am not sure what year the carb is there is no numbers or markings on it...the needles are the right size...44. If anyone can tell me the proper adjustments to make?
Texas69
Feb 4, 2012 07:13 PM
Firstcutlass
Oct 5, 2011 06:21 AM
rlafash
Aug 22, 2011 12:40 PM
Giddy
Aug 6, 2008 01:56 PM
chancestoo
Dec 8, 2006 05:22 AM
