stabil gas additive.
Old Nov 30, 2012 | 06:42 PM
jfb's Avatar
jfb
Exclamation stabil gas additive.
hey guys my 71 was out for a while and now needs to sit for the winter how long with experience can gas and stabil last really? I will check back in monday i have a lot to do.by the way if needed i can put a new bottle in over the winter.
Old Nov 30, 2012 | 08:51 PM
oldsmobiledave's Avatar
my 2 cents
I run stabil thru every fall. Sometimes it can be 5-7 months before I start the car again. Never had a problem.
Old Nov 30, 2012 | 11:02 PM
Intragration's Avatar
No matter how long it lasts, it's still better than nothing. Best way is to put it in right before you fill up, to mix it better, and then drive it home, so it works it's way through the lines and carb.
Old Dec 1, 2012 | 05:23 AM
Aron Nance's Avatar
There are two different StaBil's........one reddish, the other blueish. The blue ios a Marine additive - I use it as it is not only supposed to stabalize the gasoline over the winter time, but counter the effects of Ethanol additive(s) in the gasoline. Never had a problem with start-up.
Old Dec 1, 2012 | 06:11 AM
allyolds68's Avatar
I use the marine also, in my car and my boat
Old Dec 1, 2012 | 06:58 AM
D. Yaros's Avatar
The marine Stabil is the one you want. It not only helps prevent the gas from going bad, it reduces the amount of moisture the ethanol can absorb in a vented fuel system, such as is in our old rides.
Old Dec 1, 2012 | 09:11 AM
Does the red not reduce moisture absorption at all? I have been under the impression that the red did this to a certain extent too, and that the blue was just a stronger concentration? I've only used red and I haven't had problems. If blue is just stronger, I'd probably go with this.
Rickman48
Tech Editor's Desk
Dec 9, 2011 08:21 AM
dads66cutlass
Jul 24, 2011 10:54 AM
Dan Wirth
Oct 3, 2009 10:53 PM
AZ442
Sep 23, 2009 07:16 PM
Col Wickham
Aug 29, 2009 10:43 PM
