Squeak, squeak, squeak...only when in reverse
Old Aug 27, 2013 | 08:32 PM
rcdynamic88's Avatar
My 65 Cutlass has one annoying noise that I can't seem to pinpoint. I don't know if its a chassis, drive-train, or brake noise, so I am trying this General Discussion Forum. At any rate, when backing up, the car squeaks. When you apply the brakes and stop moving the noise of course stops too. When I drive away there is no noise what so ever. The noise seems to correspond to the rotation of something. Is there anything inside the stock drum brakes that could rub only in reverse? Can a "U" joint make a noise like that in the reverse direction only? I am trying to find this on my own by holding the door open and leaning out while backing up ( I'm sure the neighbors think I'm nuts!). I can't tell if its from the front or the back of the car, or even from right under where I sit...
Old Aug 27, 2013 | 08:47 PM
Yes, all the above can make noise in one or both directions. Just start with one item and move to the next.
Old Aug 27, 2013 | 10:21 PM
Charlie Jones's Avatar
Phantom Phixer
I would start with the U-joints.
Make sure there is no play or looseness in them.
Old Aug 28, 2013 | 01:37 AM
66luvr's Avatar
X2,,,,,from my experience, and your description, I say u-joint.
If they are only at the squeaking phase they may feel fine. So if it isn't easily spotted I suggest taking the drive shaft out to check it out.
Old Aug 28, 2013 | 03:57 AM
pogo69's Avatar
morgan
I myself would check the brakes first see if the shoes ate worn...and does it only do it when the car is cold? or warmed up?......a few of my cars did it when it was cold only and it was the brakes
Old Aug 28, 2013 | 05:04 AM
boese1978's Avatar
Check rear shoes. While rolling backwards and hearing the squeak, lightly ( do not stop the car) press the brake pedal and see if pushing the shoe closer to the drum makes it stop. I've had this same issue in the past and it was simply the shoe barely touching a slightly out of round drum- rolling in reverse ever so slightly changes the geometry of the brake hardware.
Old Aug 28, 2013 | 05:23 AM
Railguy's Avatar
That was the first thing that come to my mind.See if someone can back the car up for you while listen.
Don't blame you for not wanting to take it to a garage.I always hate it when they charge me $39.95 to tell me there's nothing wrong with it.
railguy
Old Aug 28, 2013 | 06:38 AM
brown7373's Avatar
If the above isn' it, chck the engine and tranmission mounts. A worn one could put the drive shaft and u-joints at a different angle and cause the noise.
Old Aug 28, 2013 | 06:40 AM
HurstLightning84's Avatar
W40 Kid
My gut tells me you should go for the U-joints first. They are finicky little things. My old Silverado did this same thing. It was a 5-speed, and would only squeak when there was tension on the driveshaft. Throw in the clutch and the annoying noises went away. After throwing some fresh u-joints at it, all was good. Plus it wasn't very expensive.
Old Aug 28, 2013 | 07:19 AM
It's a U-joint. Replace them both while the driveshaft is out.
Old Aug 28, 2013 | 07:40 AM
Railguy's Avatar
Or possibly just a couple shots of grease if theres fittings and no play .If it stops then squeaking then replace them.
railguy
Old Aug 28, 2013 | 07:44 PM
edzolz's Avatar
railguy
If they are factory joints, they will not have grease fittings. Take the driveshaft out and manually work the yoke and the rear cross around in a circle, both one way then the other. If there is any resistance at all, they are bad.
Old Aug 29, 2013 | 12:25 PM
The car is nearly 50 years old. If you go through the trouble of taking the driveshaft out, just put in new U-joints.
Old Aug 29, 2013 | 12:46 PM
Phantom Phixer
I like your thinking Joe. It's kinda like Mr. Goodwrench vs. Mr Shadetree.
Octania
Jan 30, 2016 09:18 PM
Octania
Jul 16, 2015 09:53 AM
Seff
Suspension & Handling
Feb 3, 2014 01:57 PM
boogiel
Oct 12, 2009 06:48 AM
Want-A-Vert
Mar 7, 2007 05:37 AM
