slip joint specs
Old June 10th, 2022 | 07:32 PM
Cruzinbill's Avatar
slip joint specs
I had new u-joints, slip joint installed, and drive shaft balanced on my '71 442 M20 4-speed. Now the slip joint bottoms out in the transmission and still a 1/4" too long to install in the companion flange. I didn't get the old slip joint. I read it needs 3/4" to 1" of clearance. Anyone have the specs for an original slip joint? The shop is telling me that's as short of slip joint they have. I don't beleve it.
Old June 11th, 2022 | 07:36 AM
442Harv's Avatar
By slip joint, do you mean the front yoke that slides into the tran? If so you must have the wrong size.
Old June 13th, 2022 | 10:30 AM
dc2x4drvr's Avatar
Are working with your original driveshaft? The ‘71’s don’t have a companion flange, just u-joints. A pic would be helpful.
Old June 13th, 2022 | 10:44 AM
Cruzinbill's Avatar
I have resolved the issue. Thanks
Old June 13th, 2022 | 04:00 PM
RetroRanger's Avatar
72 Olds CS
Can you post the resolution it may be helpful to someone in the future
Old June 13th, 2022 | 04:24 PM
v8al's Avatar
My guess was they installed the longer T400 yoke instead of the shorter yoke that was originally installed.
Old June 13th, 2022 | 04:27 PM
dc2x4drvr's Avatar
The T400 yoke would be standard for the Muncie, and apparently he was installing the original driveshaft.
Old June 13th, 2022 | 09:35 PM
Cruzinbill's Avatar
It turns out the slip yoke was correct. It had to do with how I was installing the driveshaft. I didn't have the shock studs attached to the rear-end which allows it to swing to maximum downward travel. That shortens the distance between the pinion yoke and the transmission. I jacked the rear-end up, reattached the shocks. The driveshaft went right in and has the proper clearance from the transmission to the slip yoke.
tkcutlass
May 21st, 2024 05:02 PM
tkcutlass
April 28th, 2022 09:34 PM
Macadoo
Suspension & Handling
21
July 4th, 2019 07:44 PM
kstern58
November 4th, 2014 05:48 AM
1lowdelta88
Drivetrain/Differentials
April 24th, 2013 07:48 PM
