Silly Question
Old Jul 22, 2010 | 05:34 AM
Silly Question
Something just dawned on me. How do you put a tachometer on an Olds diesel engine? There is no ignition to hook it up to...
Was a tachometer ever available in the Oldsmobile B bodies with diesel engines in the late 70s and early 80s?
Old Jul 22, 2010 | 07:36 AM
70 cutlass s's Avatar
Most newer diesel engines use a signal from the altenator they have a post for it. You have to use a tach for a diesel.
Another type of diesel tach uses a magnet pickup.
Then the link shows an interface for diesel without a altenator with the W post. Then you can use a regular tach with it.
http://www.dakotadigital.com/index.c...rod/prd128.htm
Old Jul 22, 2010 | 11:10 AM
Cool! Thanks for the info Andy. I was just curious. It sort of hit me like a ton of bricks this morning.
Old Jul 22, 2010 | 07:23 PM
There are a few options. You can use a mechanical tach - there are actually small tachs that you hold against the balancer that measure RPM directly. There are vibration tachs that measure each cylinder pulse. As for the factory, there was a special Kent Moore tool called a Tach-N-Time or something like that. The tool had a probe that fit into the cylinder on the plastic timing tab. A small magnet in the balancer was picked up by this probe for measuring RPM and also to time the injector pump.
Old Jul 23, 2010 | 05:33 AM
Thanks for the additional info Joe. I bet that tool is impossible to find now. You would have to scour Evil-bay for it.
Old Jul 23, 2010 | 04:31 PM
Actually, one shows up on ebay about once every couple of months or so.
Old Jul 24, 2010 | 08:19 AM
citcapp's Avatar
The tach in my motorhome runs off the alternator. Found that out when the tach started jumping around and I traced it down to a worn fan belt. Changed the belt tightened it to spec and the tach worked fine.
Old Jul 24, 2010 | 09:46 AM
Blk71SX's Avatar
http://www.autometer.com/cat_gaugede...id=2602&sid=12
Old Jul 24, 2010 | 09:55 AM
compedgemarine's Avatar
on my 6V92 Detroit the tach is off a signal generator that is run off the end of one of the cams. they use the same type signal generator to run the electric speedometer.
Old Jul 24, 2010 | 05:57 PM
greenslade's Avatar
older diesel trucks [80-90 ]ran the tach off a pick-up on the flywheel.that was before electronics came along.
Lady72nRob71
Oct 8, 2013 06:38 PM
yeahbuddy
Dec 19, 2011 08:40 PM
dyscookn
Sep 11, 2009 10:43 AM
Redog
May 23, 2008 09:50 AM
