Should I Spring Into Action?
Old August 11th, 2012, 12:10 PM
'69CutlassVert''s Avatar
While getting my 69 Cutlass ready for paint a couple of things became clear:
1) the pass quarter had an old wound that had been repaired,
2) that quarter was an inch and a half higher than the driver side,
3) the driver front was lower than the pass side,
4) the ride is soft
Did the rear damage warp the rear making the pass side higher or is the obviously lower driver front being soft and lower transfer causing the uneven stance in the rear?
If that makes sense, should I do new springs as well as shocks and take another look at how it sits with fresh parts?
'69CutlassVert' is offline
Old August 11th, 2012, 03:39 PM
72 cutlass455's Avatar
Could have a tweeked frame have it checked out. This could have happen when the old wound was made. Many repair shops used to do the body but not the frame. yes I know because I have a tweeked frame on mine. But also could be something less drastic.
72 cutlass455 is offline
Old August 11th, 2012, 04:58 PM
That did cross my mind, I was just wanting to think weak front springs were giving it an awkward stance. If a frame adjustment is needed would that call for me to have to realign door/fender gaps after straightening the frame?
Old August 11th, 2012, 06:16 PM
If they were all shimmed to hide the promblem more than likely. If the springs are old replacing them is not a bad thing either.
Old August 11th, 2012, 08:16 PM
Rickman48's Avatar
Just for the halibut, drill a 1/8 inch hole through the quarter and see if the outer skin was hung over the wrinkled one!
I've seen that more than once, causing weight and all kinds of alignment problems.
Rickman48 is offline
jensenracing77
May 12th, 2012 05:00 PM
doc93
May 21st, 2010 12:51 PM
gearheads78
October 14th, 2009 09:56 AM
venividivici53
August 11th, 2009 05:19 AM
joe_padavano
February 10th, 2009 05:41 PM
Quick Reply: Should I Spring Into Action?
