Screamin' Window
Screamin' Window
Im new here and will have lots of questions. My first is: The passenger side window makes an awful screeching noise when rolled down (manual crank). Im assuming its the outer squeegie, if I pull on the glass as Im winding it down its quiet(er). Any suggestions?
Thanks -
Phillip
Thanks -
Phillip
Phillip, are there any scratches on the window that might indicate it's rubbing on parts inside the door? If not, then as you said it could be the window felts. Especially if you've never replaced them.
I replaced the window felts on my 71 98. They are also sometimes called cat whiskers. BTW, what kind of car is it?
If you take the door panel off and roll the window all the way down you will be able to tell if the window needs to come out. The window felts are secured with screws and the window blocks one or two of them.
When I replaced my felts, I found that removing the block (don't know the actual name for it) inside the door underneath the window, allowed the window to be rolled down a little further than the norm. This allowed me to replace the felts easily. The pain in the but was replacing the felts on the door panel itself. Bending the old staples, so that I could remove them w/o damaging the panel was tedious to say the least.
Chip, that's awesome. I wasn't sure if the windows needed to come out or not in a Cutlass. I guess I should have checked the window actuator and the innards of my door when I did the window felts on my 71 98. Oh well, I had to realign all the windows anyways since I put new weather stripping on the car (not an easy task for a 4 door hardtop).
wyteon
Vista Cruiser & Wagons
Nov 30, 2018 11:33 AM
f-85
Jan 16, 2012 06:10 AM
leepear
Apr 22, 2011 02:22 PM
