Scan tool say unable to communicate
Dad has a 2010 Malibu with a check engine light. I have tried 3 different scan tools, I get the same message that it’s unable to communicate. I have cleaned/inspected grounds and battery cables, I don’t see anything obvious under the hood. The car runs fine, everything works as expected. Only issue is the check engine light.
Anyone in readerland have any ideas where to begin looking?
Check this out. I found it with a quick Google search.
https://rustyautos.com/obd-wont-connect-to-ecu/
I've troubleshot this before - it's most often the on-board wire clips have opened too far and need to be tightened up - dozens of videos on tightening them up...here's one....the point is to tighten up (close the openings) the clip openings.
I really hope that’s the issue. At one point my scan tool was able to pull codes. This is a recent issue.
Matt, on my 99 Chev PU, mine wasn't able to read either. The cause was the cigar lighter fuse was blown. Changed it out and the scan tool worked.
I realize your Chevy is 11 years newer but that's what I came across once. Good luck and let us know how it turns out.
Like so many things in life, this morning was a feeling of triumph, followed shortly by crushing defeat.
I pulled the ALDL connector from the dash. I used an old Delphi 150 male terminal to verify decent pin contact. One pin did feel loser than the others, I replaced that terminal. Success! I was able to retrieve the codes. The one that caught my attention was the P1174, cylinder imbalance. This code was in the car several months ago, based on a “YouTube” certified tech video, I replaced both O2 sensors. I don’t recall if I was able to clear the code at that time due to the scan tool not communicating. I was able to clear it this time. The car also had some other older BCM codes.
Now, the defeat part.
On a test drive, I heard the scan tool beep, and a message saying communication lost. Great big steaming piles of horse excrement!! Guess that wasn’t the issue.
IMO, you replaced one pin but you didn't replace or tighten other pins; in particular, since the one loose pin, as you stated yourself, was the issue. Replace or tighten the other pins my suggestion.
Matt - I have a 2003 Ford F-250 diesel (195K miles) w/ significant routine major & minor maintenance during the past 20 yrs. of ownership. Something I learned years ago is the ability to permanently clear memory & codes to provide the ability to start fresh. The chap in this video has some excellent videos on Ford truck maintenance. This is the procedure I've employed and it works flawlessly (on my truck). I've had to replace the fuse box (windshield water leakage destroyed it) & a couple items over the years where I wanted to ensure all "memory" was cleared (not simply the codes themselves). This allowed me to start fresh. The vehicle then learns the idle trim, fuel ratios, shift points, etc. I can't speak whether it will work for you, but you have enough knowledge to know how this works and why this works. Whether you call modules PCM, ECM, etc. they all talk with one another along the CAN bus and this process clears the memory maintained for those modules communication. Just thought I'd throw that out there for you in the off-chance it may be something for you to consider and ponder.
Not certain that was "exactly" how you intended to ask your question, since you would still be able to troubleshoot anything in the future but memory of anything "prior" to a clear memory would be lost. A good analogy is likened to clearing CMOS on your computer.
I'll use the example of fixing a "Service Stabilitrak soon / reduced engine power" dash message (I don't recall the codes it put out). The codes indicated that the throttle position sensor was causing the issue. Since it was a drive-by-wire throttle body, I knew that the sensor was no longer recognizing proper accel pedal input and that the throttle body needed to be replaced. The TPS was not a serviceable item. After replacement, I cleared the codes. Test drove, issue never returned.
In this situation, what good would having those codes stored in memory serve? The problem was fixed.
I checked every fuse I could find. The power port in the ashtray does have power.
I suppose I’m going to have to get a real service manual for this car, and some of the other junk in our fleet. I really don’t like dragging a laptop around, I’d prefer a REAL paper book. The cheap chiltons books are worthless in my opinion, and this car is too new for old school books.
My point was if you permanently clear memory, then the memory is incapable of ever storing data again.
per·ma·nent·ly
/ˈpərm(ə)nən(t)lē/
adverb
https://www.merriam-webster.com/dictionary/permanently
per·ma·nent·ly ˈpər-mə-nənt-lē
ˈpərm-nənt-
Synonyms of permanently
: in a permanent manner : in a way that continues without changing or ending : in a way that is not brief or temporary
per·ma·nent·ly
/ˈpərm(ə)nən(t)lē/
adverb
- in a way that lasts or remains unchanged indefinitely; for all time.
permanently
adverb
ˈpərm-nənt-
You have permanently removed what was previously "stored" in memory, if that makes you feel better.
noun: memory; plural noun: memories
powers of recall
recall
powers of retention
retention
mind
- 1.
the faculty by which the mind stores and remembers information.
"I've a great memory for faces"- the mind regarded as a store of things remembered.
"he searched his memory frantically for an answer"
h
Similar:
ability to remember
powers of recall
recall
powers of retention
retention
mind
- h
Opposite:
forgetfulness
- h
- 2.
something remembered from the past; a recollection.
"one of my earliest memories is of sitting on his knee"
per·ma·nent·ly
/ˈpərm(ə)nən(t)lē/
adverb
ˈpərm-nənt-
per·ma·nent·ly
/ˈpərm(ə)nən(t)lē/
adverb
permanently
adverb
ˈpərm-nənt-
Just so ya know, I work in a semiconductor industry so I’m a bit aware of memory. SRAM, FRAM, EEPROM, FLASH.
I just have memory loss and can’t remember which ones do what due to that chain saw accident.
And knock it off with acting condescending, I thought you were better than that.
VikingBlue
September 20th, 2013 12:55 PM
