"Check Engine" light burnt out?
Old January 30th, 2007, 05:11 PM
sean000's Avatar
Anyone know if there is a way to retrieve the ECM codes without the use of the "check engine" light?
How hard would it be to replace the bulb in the check engine light on a 83 cutlass?
Could there be another reason the check engine light isn't coming on at all...not even on start up?
Thanks in advance,
sean000
sean000 is offline
Old January 31st, 2007, 05:03 PM
ozoneblue's Avatar
Wink Check Engine Light
Test all your fuses with IGN on & park lps on All fuses should have power Check with 12v test light .Also check small wire at ALT should have power with ign on
ozoneblue is offline
panther80
September 17th, 2012 07:30 AM
81 regency
April 21st, 2011 06:18 PM
HouTXCutlass
August 16th, 2010 11:06 AM
dhoff
March 6th, 2010 06:47 PM
JACK RYAN
Intrigue
December 28th, 2008 09:27 PM
Quick Reply: "Check Engine" light burnt out?
