Rear disc brake conversion from LS
Old April 10th, 2017, 06:56 PM
Olds442toro's Avatar
anyone done the rear disc conversion using ls brakes with ebrake shoes. Sway for c clip rear end pretty easy. Question is has anyone done the bolt in olds axles and did this swap what did you have to do to make it work properly and align correctly??
Olds442toro is offline
Old April 11th, 2017, 08:42 AM
Rodney
cdrod's Avatar
'01 Blazer rear disc
Olds442:
I have done a similar swap with Blazer rear discs. The LS rears rotors and calipers were bigger than I needed and the Blazer backing plate has provision for the parking brake cable where the LS set-up required fab'ing up a a bracket. Here's a link to my build page with some pics - the brakes start around post #67. The process will be similar with the LS parts but the spacing and dimensions will likely no be the same as mine.
https://classicoldsmobile.com/forums...ertible-2.html
Rodney
cdrod is offline
Old April 11th, 2017, 05:30 PM
Good to know
Originally Posted by cdrod
Olds442:
thank you have looke at your post and for what they charge here in pull a part yards going to get S-10 set up also and use whichever I like the best thank you again
Rodney
Old April 12th, 2017, 09:49 AM
ART T's Avatar
I used the Blazer setup on my 64 Cutlass. Pretty easy swap. Double check the thickness of the sleeve. I used wheel studs from NAPA, 641-1268.
ART T is offline
Old April 12th, 2017, 11:51 AM
thank you you will be a while before I start mine but getting parts and prices together so will have them when it's time
Mocephus
October 1st, 2021 09:45 AM
68442Convertible
Brakes/Hydraulic Systems
June 8th, 2016 08:15 PM
Maverick
June 26th, 2013 08:21 AM
ricardo
July 27th, 2010 05:26 AM
nh4kidsdad
February 12th, 2009 04:49 AM
Quick Reply: Rear disc brake conversion from LS
