A real Oldsmobile rocket!
Old November 17th, 2017, 11:58 AM
Every so often, my hobby and my day job intersect.
I was doing some research for a project and came across a paper by the Air Force Research Lab from 2001 about development work on a pulse detonation engine (PDE). Yes, that's an outgrowth of the German V1 "buzz bomb" pulse jet engines from WWII.
In this case, AFRL was trying to build a very low cost engine for disposable use, such as in drones or missiles. They tried to adapt an existing automotive cylinder head as the basis for this PDE demo. The cylinder head selected was none other that one from a Quad 4. This demo engine had four tubes, each firing at up to 100 times a second. They succeeded in a successful firing on their first attempt, using propane and air. Later tests used hydrogen and air. Yes, the stock spark plug was used to fire the mixture.
joe_padavano is online now
Old November 17th, 2017, 12:23 PM
Gerald Nickels's Avatar
Most likely Baddd andy has seen it already. but thanks I didn't know.
Gerald
Gerald Nickels is offline
Old November 19th, 2017, 12:00 PM
Wow that is cool...
Greg Rogers is offline
Old November 19th, 2017, 01:49 PM
ELY442's Avatar
The spark plug is in the middle, is that considered a "Hemi"?
ELY442 is offline
Old November 19th, 2017, 01:59 PM
Spark plug in the middle does not make it a Hemi. Hemi stands for hemispherical combustion chamber. In this case, that's tough to do with four valves. It's actually more of a pent roof chamber, since the intake valve stems are parallel, as are the exhaust valve stems. To be a true hemispherical chamber, all valve stems would need to be on a radius from the center of the chamber. That's possible but not practical with four valves.
Old November 19th, 2017, 04:54 PM
garage goat2's Avatar
So What is your daytime job?
garage goat2 is offline
Mak
53
November 18th, 2011 04:23 PM
J'ville
August 28th, 2006 05:21 PM
<Eddie>
November 1st, 2005 07:30 PM
AC
February 7th, 2005 04:13 PM
<helpme>
September 27th, 2004 06:21 PM
Quick Reply: A real Oldsmobile rocket!
