Rally Pac Tach Off
Rally Pac Tach Off
I have been trying to figure out why my Rally Pac Tach is reading high compared to actual RPM and still have not clue. Without having removed the tach I simply did some reading with a timing light and compared to what was being displayed on the tach itself. The below is the chart of Tach versus Actual RPM.
Just a little background, this is a manual 69 442 with 455 and HEI distributor. Any guidance would be great and help me immensely.
Actual RPM --- TACH RPM
760 (idle) --- 1000
1500 --- 2000
2000 ---2800
Regards
Sean
760 (idle) --- 1000
1500 --- 2000
2000 ---2800
Regards
Sean
I completely agree. My cars and my customers cars have all been off. I guess the factory didn't worry about being accurate as long as it looked good. ~BOB
Update
So I got the tach calibrated this weekend by simply connecting a digital timing light with RPM display and making it visible while I was behind the wheel. I then reached up behind the dash to access the rear of the tach where there is the small adjuster screw (covered by foil tape). The best way I found of adjusting the screw was to us a phillips socket insert and just insert into the screw hole until you feel the screw being engaged. I then gave the car some gas until about 2500 RPM on the timing light and held it while I tried to match by adjusting the tach screw. This is very sensitive so it might take a few tries to get it right. Only about 30mins of work and it now appears that the tach is as good as new.
Sean
Sean
On a tach-related note; has anyone ever seen an extra fuse taped to the bottom from the factory?? I swear I had to be the first to remove this tach from my 72 U code Supreme which came with the gauges from the factory and that I have owned since '94.
sportsicon
March 3rd, 2015 09:55 PM
