Rally Pac Tach Off
Old Jul 4, 2015 | 09:55 AM
Boilerz25's Avatar
Rally Pac Tach Off
I have been trying to figure out why my Rally Pac Tach is reading high compared to actual RPM and still have not clue. Without having removed the tach I simply did some reading with a timing light and compared to what was being displayed on the tach itself. The below is the chart of Tach versus Actual RPM.
Just a little background, this is a manual 69 442 with 455 and HEI distributor. Any guidance would be great and help me immensely.
Actual RPM --- TACH RPM
760 (idle) --- 1000
1500 --- 2000
2000 ---2800
Regards
Sean
Old Jul 4, 2015 | 03:13 PM
allyolds68's Avatar
Mine is the same. 68 Rallye pac tach. No HEI. I guess the up-side is my 70 455 red lines at about 6500 RPM's. :/
Old Jul 4, 2015 | 06:08 PM
Indy_68_S's Avatar
I don't know anything about these tachs, but the 25% descrepancy is the diff between 6 and 8 cyls.
Old Jul 6, 2015 | 10:09 AM
pizza442's Avatar
Every car I've had over the last 30 years w the Pac (factory or added by me) was off to some degree similar to yours. NEVER seen one accurate
Old Jul 6, 2015 | 10:31 AM
frankr442's Avatar
It's been 20 years since I had mine out, but I think I remember an adjustment screw in the back.
Old Jul 6, 2015 | 01:04 PM
Boilerz25's Avatar
Frank,
Correct, there is a adjustment screw on the back (behind the foil tape). I will try and pull the gauge and see if I can get it close to actual.
Sean
Old Jul 6, 2015 | 06:42 PM
442Harv's Avatar
My 70 was off took it out and hooked up another tack, and run the two together, and adjusted the back screw. A little move moves it a lot, so may take a couple try's. Also check it at low and high speed.
Old Jul 7, 2015 | 05:12 AM
frankr442's Avatar
That adjustment is very sensitive. I turned mine back and forth across the full range (gently) to try to clean the control. It seemed to help.
Old Jul 7, 2015 | 01:55 PM
Carshinebob's Avatar
I completely agree. My cars and my customers cars have all been off. I guess the factory didn't worry about being accurate as long as it looked good. ~BOB
Old Jul 13, 2015 | 12:04 PM
Boilerz25's Avatar
Update
So I got the tach calibrated this weekend by simply connecting a digital timing light with RPM display and making it visible while I was behind the wheel. I then reached up behind the dash to access the rear of the tach where there is the small adjuster screw (covered by foil tape). The best way I found of adjusting the screw was to us a phillips socket insert and just insert into the screw hole until you feel the screw being engaged. I then gave the car some gas until about 2500 RPM on the timing light and held it while I tried to match by adjusting the tach screw. This is very sensitive so it might take a few tries to get it right. Only about 30mins of work and it now appears that the tach is as good as new.
Sean
Old Oct 4, 2024 | 01:31 PM
Joel's Avatar
Does anyone know if it is the same for a '67? The tack in my '67 442 is reading about 20% high. I'd like to get it dialed in.
Old Oct 6, 2024 | 09:36 AM
pizza442's Avatar
On a tach-related note; has anyone ever seen an extra fuse taped to the bottom from the factory?? I swear I had to be the first to remove this tach from my 72 U code Supreme which came with the gauges from the factory and that I have owned since '94.
Del70
Oct 2, 2025 11:32 AM
sportsicon
Mar 3, 2015 08:55 PM
BeenThere
May 31, 2014 03:39 AM
StickW31
Jan 8, 2013 08:08 AM
agtw31
May 23, 2010 12:15 PM
