Radio not playing
Old Aug 2, 2020 | 12:41 PM
jacob94's Avatar
Radio not playing
I put a new fuse in but my radio still will not turn on. Does anyone have any troubleshooting suggestions?
Old Aug 2, 2020 | 01:00 PM
70W-32's Avatar
What year and model?
Old Aug 2, 2020 | 01:04 PM
jacob94's Avatar
Originally Posted by 70w-32
what year and model?
1970 442
Old Aug 2, 2020 | 01:53 PM
rocketraider's Avatar
Oldsdruid
Is it the factory radio?
Old Aug 2, 2020 | 02:12 PM
jacob94's Avatar
yes
Old Aug 2, 2020 | 02:31 PM
VC455's Avatar
Barely Registered
1. Was the fuse you replaced blown?
2. Did you have symptoms before the radio stopped playing? For example, would it work for a few minutes and then stop?
Old Aug 2, 2020 | 02:34 PM
jacob94's Avatar
1. the fuse was not blown but I felt putting a new one might help.
2. no symptoms. I just turned the car on and it just didn’t work.
Old Aug 2, 2020 | 02:42 PM
Oldsdruid
Is this a factory air car? I ask because to get at the radio, a/c ductwork has to come off.
AM, AM-FM, with or without 8-track tape player?
My first guess is the wiring may be unplugged at the radio itself. Worst case is its output transistor has failed. Do you hear a pop, thump, or any noise at all when you turn it on?
Old Aug 2, 2020 | 03:08 PM
Oldsdruid
Also- does this car still have its windshield antenna, or has it had a mast antenna installed? If antenna or cable is bad, or not plugged into the radio, usually no sound.
Old Aug 2, 2020 | 03:19 PM
RandyS's Avatar
Is there a pop thru the speakers, or any indication that there is power to the radio when you turn it on? Does the radio light come on? If no, then as mentioned the plug at the rear may have come loose. If yes, do you hear any static or a hum when the volume is all the way up? If you don't hear anything, and the plug is seated, your radio is probably dead. Not a lost cause, it can be repaired.
Old Aug 2, 2020 | 04:42 PM
jacob94's Avatar
so I played are like with the radio and got the AM portion playing but still could not get the FM portion to play.
Old Aug 2, 2020 | 05:16 PM
Oldsdruid
Slide the AM-FM selector bar back and forth sharply a few times. May be gunked up from lack of use.
Old Aug 2, 2020 | 05:26 PM
jacob94's Avatar
sounds like a plan. Thanks for your help!
Old Aug 2, 2020 | 05:35 PM
Spray the slider and all of the ***** HEAVILY with a good HD electronics contact cleaner while sliding the bar and rotating the ***** VIGOROUSLY. Radioshack, Fastenal, etc sell contact cleaners.
Old Aug 2, 2020 | 05:38 PM
jacob94's Avatar
perfect
Old Aug 2, 2020 | 09:37 PM
cjsdad's Avatar
Be careful with the contact cleaner. It will remove paint. If any portion of the dash is painted, like the A/C vents along the bottom of the dash, the cleaner may effect it. Have an old towel or something similar to catch the run-off as you spray the cleaner. Also, you want the contact cleaner to get into the controls of the radio so spray it on the shafts where it can wick into them as you rotate them. Spray it into the rear of the AM/FM selector as well. Operate the controls vigorously like mentioned above, and hopefully it will clean up well.
edzolz
Aug 1, 2020 10:31 AM
71cutlassdroptop
May 18, 2014 07:39 PM
Kace
Jun 27, 2012 07:37 PM
ELECMAN
May 29, 2010 11:04 AM
bjtstarfire
Jan 21, 2008 03:31 PM
