Qudrajet rebuild
Old Oct 8, 2015 | 12:53 PM
JpMotorsports's Avatar
Qudrajet rebuild
I was wondering what the average cost is to have a 350 q-jet carb rebuilt? I have one that was rebuilt by my uncle but not sure if its all in tune ( he mainly dose model a carbs) Any incite would be great
Old Oct 8, 2015 | 01:04 PM
rcorrigan5's Avatar
Randy C.
My experience tells me it would cost about $400 to have a qjet-knowledgeable person to rebuild your carburetor.
Randy C.
Old Oct 8, 2015 | 01:07 PM
GEARMAN69's Avatar
if its clean inside and the gasket on top plate and accelerator pump seal is still good and pliable it may not need anything but a re-calibration depending on your cars set up and intended use. Factory metering rod jet combos can be pretty lean designed for heated and restrictive air intake on a hot 195-200 degree running engine. primary jet 71-72 primary rod 42-44 would work good with open element air cleaner and 160-180 T stat
Old Oct 8, 2015 | 01:10 PM
Randy C.
Thank you. The car runs good and with some tweaking its gotten better. Just always doing a little cost calculating
Old Oct 8, 2015 | 02:16 PM
ELY442's Avatar
Randy C.
X2, that's how much I was charged. The rebuilder calibrated my carb that matches the cam that I have in my car.
Old Oct 8, 2015 | 04:25 PM
bw1339's Avatar
Buy a decent core (so you don't mess up your carburetor) and this book:
How to Rebuild & Modify Rochester Quadrajet Carburetors (S-a Design): Cliff Ruggles: 9781932494181: Amazon.com: Books How to Rebuild & Modify Rochester Quadrajet Carburetors (S-a Design): Cliff Ruggles: 9781932494181: Amazon.com: Books
I avoided quadrajets for a long time and now I am fascinated by the genious that went into designing them
Old Oct 9, 2015 | 06:40 AM
bw1339 I will def look into getting this book. Thank you guys
Old Oct 9, 2015 | 06:56 AM
GEARMAN69's Avatar
The Quadrajet said ......"To know me is to Love me "
Old Oct 10, 2015 | 07:51 PM
BackInTheGame's Avatar
Thumbs up Not hard to do
I rebuilt my own back in the day. I swapped out a two BBL and manifold for the 4BBL. I was 17 and too naive to think it may be difficult. It ran perfectly afterward. Do not fear the Mighty Q-Jet!
Old Oct 10, 2015 | 07:53 PM
biggus's Avatar
Just paid $270, correction, my Wife paid $270.
Old Oct 12, 2015 | 09:00 AM
chip-powell's Avatar
They're not too hard to do on your own. Don't psych yourself out about it. It can be knocked out during a Saturday afternoon.
A decent rebuild kit will run you somewhere between $20-$40. Take a look on Amazon. I did mine 2 years ago and she's still running great.
Old Oct 19, 2015 | 07:30 AM
this weekend I adjusted the carb a little bit, replaced the accelerator pump and also replaced the non working/ poor working choke assy with a later qjet electric. Boy dose it run a million times better than before!
Old Oct 19, 2015 | 07:50 AM
GEARMAN69's Avatar
Excellent !
Old Oct 19, 2015 | 12:50 PM
Sporty45's Avatar
Just picked one up at my local Pep Boys today. On sale for $10.50!!!
http://www.pepboys.com/product/details/9984624/00830
Old Oct 19, 2015 | 01:38 PM
Looks like a good book I'll check my local pepboys to see if they carry it
Old Oct 19, 2015 | 05:03 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
As long as it is in good shape, you rebuild yourself if you are fimilar with carbs. Mine ran awful even after a rebuild, pretty it was plugged up somewhere. I got Ken from Everyday Performance to rebuild mine, included secondary throttle and I provided the carb to rebuild for around $250. It runs great.
Tedd Thompson
Mar 24, 2013 06:52 AM
Tedd Thompson
Jan 24, 2012 05:54 PM
442dreamer
Aug 23, 2011 07:28 AM
Gary's 2 442-S
Aug 14, 2011 12:04 PM
442oldslawyer
Apr 29, 2010 09:22 PM
