Q Jet gaskets
Old Jul 31, 2013 | 09:07 AM
The Bug Man's Avatar
Q Jet gaskets
Just did a rebuild on 70 Qjet # 7040251 RJ 2809. Kit came with two gaskets. One is very thin and has two openings for the secondary's. The other is 1/8" thick with grommets in the bolt holes and has a single opening for the secondary's. It's going back on my 442 restoration. It's going to be used as a cruiser with maybe an occasional session of painting the asphalt with black stripes. Any suggestions on which gasket to use ?
Old Jul 31, 2013 | 09:08 AM
What manifold are you running?
Old Jul 31, 2013 | 09:11 AM
intake
OOPs guess that might help... Repop W30 from the parts place
Old Jul 31, 2013 | 09:24 AM
I would use the 4 hole thin gasket. I've experienced some off idle stumble using an open plenum gasket on a dual plane manifold. Those gaskets are for heat isolation, and are available with your manifold setup.
Old Jul 31, 2013 | 09:34 AM
gaskets
Thanks. I thought the open array might be better suited for strip use / WOT application. I'll use the thin one
Old Jul 31, 2013 | 10:09 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Or get yourself the insulator style 4 holer to keep heat wick at bay. Did you plug the crossovers in the heads or intake?
Skitch72
Oct 27, 2013 09:00 AM
oldzy
Aug 29, 2010 09:18 PM
DAN76
Jul 24, 2009 09:01 AM
dallas6778
Nov 20, 2007 10:04 AM
Deltarocket
Jun 5, 2007 06:54 AM
