Polyurethane control arm bushings
Old Jan 17, 2018 | 02:45 PM
dennis_30281's Avatar
Anybody try to make polyurethane control arm bushings from the gutted outer shells and inner spacer by pouring polyurethane in the gap in between?
Dennis
Old Jan 18, 2018 | 05:49 AM
Why not just buy control arm bushings? They're generally available for most Oldsmobiles.
Old Jan 18, 2018 | 07:06 AM
I wish that I could find where they are available without having to get a second mortgage. For a 62" Starfire the rear control arm bushings and only available from Rare Parts at $104+ for 2 and then you have to press out the center bushing and press in the correct 5/8" center bushing from your old oem bushings. The front upper control arm bushings are another story...Moog has quit making them and I'm afraid to call those parts rapists Fusicks. Well that's all of off my chest.
Thanks Dennis
Old Jan 18, 2018 | 07:58 AM
Well, I suppose you could craft your own rear control arm bushings. I checked around and you can get front end suspension kits from Kanter, but they aren't cheap. Plus, they might be Chinesium instead of polyurethane. It's worth looking:
https://www.kanter.com/
Old Jan 18, 2018 | 11:24 AM
Thank you, will check...just frustrated.
Dennis
David DeCan
Jun 8, 2017 05:47 PM
therobski
Oct 24, 2009 01:54 PM
olds1968
Jun 10, 2009 12:41 PM
J-(Chicago)
Jul 13, 2008 08:31 PM
tiparosa
Feb 26, 2007 10:43 PM
