Polyurethane Control Arm Bushings vs. Rubber
Old Jun 8, 2017 | 10:30 AM
David DeCan's Avatar
Installing Chev 12 bolt in 70 Cutlass. Installing boxed lowers that came with rubber bushings. Replacing all bushings with new rear end.
Question: Thoughts on rubber control arm bushings versus polyurethane?
Thank you
Old Jun 8, 2017 | 10:33 AM
David, I replaced the control arm bushings and stabilizer bar bushings on my 64 98 many years ago with rubber components. I figured since a 98 is a luxury car there was no need for "performance" bushings. I've heard that the poly bushings can squeak; however, I don't know if this is an old wives tale or reputable feedback.
Old Jun 8, 2017 | 10:38 AM
Poly bushings have their place for more performance oriented suspensions. If you liked the ride before, go with the rubber.
Old Jun 8, 2017 | 11:50 AM
Poly bushings significantly reduce unwanted suspension motion, improving handling and response. This comes with the cost of degraded ride quality. Your call. If you choose poly, DO NOT use poly bushings in the front end of the upper control arms on the rear suspension. The GM four link suspension requires the upper arms to twist slightly when cornering. The more compliant stock rubber bushings allow this to happen. Poly bushings do not, and cause suspension binding as a result. It is acceptable (and relatively common) to run rubber bushings in the front of the upper arms and poly everywhere else. If you really want to eliminate the unwanted suspension motion, use the all metal ball joint bushings at the front of the upper arms.
Old Jun 8, 2017 | 05:00 PM
TripDeuces's Avatar
Joe, any idea who makes those joints in your pic. I could use those dust and dirt guards in them.
Old Jun 8, 2017 | 05:47 PM
That particular one is made by AFCO. They are sold by Speedway, Pit Stop USA, etc.
http://pitstopusa.com/i-10286956-afc...m-midsize.html
http://www.speedwaymotors.com/1973-8...hing,9021.html
J.O.
May 15, 2016 01:39 PM
ah64pilot
Apr 26, 2011 09:22 PM
Jolly Green
Suspension & Handling
May 31, 2009 10:08 PM
J-(Chicago)
Jul 13, 2008 08:31 PM
tiparosa
Feb 26, 2007 10:43 PM
