Piston ring filer
Old Feb 24, 2022 | 07:28 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Piston ring filer
Looking at picking up a reasonable priced hand crank model. Looking for something easy to use to set the ring gap on my 357 in the next couple of weeks. Thanks in advance.
Old Feb 24, 2022 | 07:39 AM
oddball's Avatar
They all suck.
There's the small wheel ones with the round base and the big wheel ones with the square base. All the same junk from the same factory, buy whatever is cheapest.
My latest discovery is if you're using super thin 1mm rings with the round base filer, the ring will slip under the ring guide thingy (lots of slop in the assembly), letting the ring wobble around and totally messing up the cut. Had to disassemble and put in little spacers.
Get a diamond stone to clean up *all* edges after filing, too.
The next option is the Proform electric filer with dial gauge, but I can see where that requires some practice to get repeatable results. The Total Seal unit is the bee's knees, and they charge appropriately.
Old Feb 24, 2022 | 08:23 AM
Yes, it is the 1mm Mahle ring pack. Thanks, I have seen mixed reviews on most of the ones on Amazon I have checked out.
Old Feb 24, 2022 | 01:34 PM
Ordered this one off Amazon.
It looks the exact same as the basic Summit brand ring filer.
Old Feb 24, 2022 | 07:24 PM
oddball's Avatar
Yup, that's the style that I had to modify. Just take your time and keep checking. It take a while.
Old Feb 25, 2022 | 03:37 AM
I'm okay with it taking days to complete.
jskorz
Jul 16, 2021 05:20 AM
Jhucks03
Apr 5, 2019 05:40 AM
1966Oldsmobile
Jun 13, 2014 05:26 PM
pogo69
May 19, 2014 01:50 PM
OLDSmobility
May 13, 2011 07:47 PM
