Pics of 70 riding alittle high in the rear?
I agree. The profile looks great as is. Not only will the rear springs settle a little bit, should you put any weight in the rear seat or trunk you'll find the stance is ideal. Very nice red-stripes, as well.
Well, having the right height is one thing, but having/getting the correct suspension ride is what you're really after I would argue. Even old dead mushy springs can remain at good ride height but feel like slushy marshmallows when driving.
I installed UMI Performance 1967-1972 GM A-Body Factory Height Spring Set. They sell the fronts separately. Ride height came out spot-on.
Winter Project - '71 CS Suspension
Yes, a bit higher than factory spec. I have the same size wheels / tires with FE2 springs and mine sits lower:
Front = 8 1/2"
Rear = 9 3/8"
Front = 8 1/2"
Rear = 9 3/8"
