Ok my Quadrajet guru's.......
Old Nov 1, 2009 | 06:35 AM
nukesec1's Avatar
Once again I have muffed! Got up bright and early in the cold to route vac lines, refill antifreeze, and do final checks to make sure the Cutty was ready to start. Well, while routing vac lines I remembered that there was this little white plastic removable vac nipple that came out of the carb. So I ask myself? "Self, did that white plastic thing get put back in?" As luck would have it, there it was rolling around in the bottom of the carb rebuild kit box. I seem to remember that it came out of the throttle base, but upon close inspection, I can't see where it goes. I can't find the hole it went into and come to think of it I'm not 100% sure where the vac line went that hooked to it. Any help? Please!
Old Nov 1, 2009 | 06:38 AM
nukesec1's Avatar
Uh, oh! I think I just found out where it went. I think the choke is going to have to come back off the carb. DAMN!
Old Nov 1, 2009 | 07:04 AM
MX442's Avatar
Is it the white plastic plug between the choke housing and the carb bowl?
Old Nov 1, 2009 | 06:19 PM
nukesec1's Avatar
Yes it is. I feel like a dork!
2blu442
Dec 8, 2009 09:34 PM
geckonz08
Dec 5, 2009 05:48 AM
MN71W30
Feb 26, 2009 05:59 AM
johnfharding
Sep 30, 2008 09:57 PM
rix442
Aug 26, 2008 08:57 AM
