Ok my Quadrajet guru's.......
Once again I have muffed! Got up bright and early in the cold to route vac lines, refill antifreeze, and do final checks to make sure the Cutty was ready to start. Well, while routing vac lines I remembered that there was this little white plastic removable vac nipple that came out of the carb. So I ask myself? "Self, did that white plastic thing get put back in?" As luck would have it, there it was rolling around in the bottom of the carb rebuild kit box. I seem to remember that it came out of the throttle base, but upon close inspection, I can't see where it goes. I can't find the hole it went into and come to think of it I'm not 100% sure where the vac line went that hooked to it. Any help? Please!
