Not Oldsmobile but GMC
Hope I'm not offending anyone by posting this. I just want a quick answer and since I am registered here I figued a quicky would be ok. (?) It is GMC but not Olds.
I have a GMC truck, 1993 Sierra 1500. 230K miles. Trans was worked on around 140K miles. I have a problem that came up yesterday, quite abruptly.
Gas peddle is mushy. I step on the gas and get a weak slow motion response. The engine revs but the truck only creeps forward. I have to almost red-line it to get to shift but it DOES shift into second and eventually thrid gear.
At stop signs it tends to die. Restart is positive and immediate but I have to keep my foot on the gas, in nuetral, to keep it running.
Any ideas?
Thanks,
Robert
Any ideas?
Thanks,
Robert
Transmission started slipping at around 140K it was rebuilt.
No trouble since then.
Fluid is at FULL line and clean. Does not smell burnt.
No obvious signs of of anything. I drove about 8 miles to a Mall and then took the wife to lunch. Everything was fine until I started home after lunch. I had not noticed any symptoms prior except for a little "trailer hitching" which I actually attributed to the crummy roads we have around here. It was very slight and I really don't know if it was the roads or something else but it was not an obvious, in your face, kind of symptom.
Since the engine starts fine I'm thinking it's not the motor.
IS there a trouble light illuminated? If so pull the codes and see what they say.
FWIW, I agree with Rob. If you had transmission troubles in the past chances are you have the problems again. A friend of mine has an early 90s GMC Yukon. It had transmission troubles as well. I believe they were notorious for weak transmissions. Search the internet for a full sized truck forum. They might run into this problem as often as we run into Slim Jim problems.
Problem fixed........Only one fuel injector port was functioning. 4 cylinders out of 8 runs like crap!
New port and new plugs and she's good as new.
The symptoms wouldn't point to that right off but after a few checks here and there, it stood out like a sore thumb.
Thanks anyway!
Thanks anyway!
jensenracing77
May 29th, 2015 01:20 PM
gearheads78
February 14th, 2009 12:28 PM
Andrew240
December 22nd, 2007 01:54 PM
