Mystery Hood
Old August 25th, 2023 | 09:36 AM
Loweralabama's Avatar
Mystery Hood
Hello:
Can anyone on here identify what hood this is? I have never seen one quite like this. I have seen low profile cowl and ram air but not a combination quite like this. They gentleman told me it came off of wrecked 442 but I have searched far and wide for this same hood and have not seen a pic yet showing the same hood. Please identify the year and or if you know this to be just a custom hood. If it is custom and you know the manufacturer please let me know. Thanks in advance for your help and cooperation.
Old August 25th, 2023 | 09:41 AM
Rocket Renegade!
Fiberglass or steel?
Old August 25th, 2023 | 09:49 AM
The gentleman said a factory steel 72 model hood. The car is an 86 so that doesn't jive. That is why I shared it on here to figure out what it really was. I sort of like it....unique.
Old August 25th, 2023 | 10:30 AM
It's someones goofy home built rendition with 1978 Z28 hood incerts.
Old August 25th, 2023 | 10:33 AM
70W-32's Avatar
Aftermarket or homemade. Never was on a production car
Old August 25th, 2023 | 10:50 AM
Now that you mention it those Z28 inlets do look familiar and that makes sense. Thanks for the reply.
Old August 25th, 2023 | 10:56 AM
GN1220's Avatar
The way it's bowed I would definitely say fiberglass. You might also mention to the guy giving you that information that he has no idea what he is talking about.
Old August 25th, 2023 | 11:24 AM
Thanks for that information and reply.
Old August 25th, 2023 | 11:36 AM
It's an aftermarket cowl induction hood that someone has cut out and added aftermarket NACA scoops to. You can get G-body cowl induction hoods in both metal and fiberglass, in a variety of scoop heights. The NACA scoops are available from a number of vendors in different sizes and configurations.
Old August 25th, 2023 | 12:02 PM
That does look and sound like this particular application. Thanks for the reply and information.
Old August 25th, 2023 | 02:14 PM
Wow, if those scoops are open and functional, then it's a "pass through" hood. The air comes in the front scoops and blows right out the rear cowl opening. Engineering Fail
Old August 25th, 2023 | 03:25 PM
No offense to our particular new member, but the man IS in Lower Alabama, where this sort of thing occurs.
Old August 25th, 2023 | 03:39 PM
crossboss's Avatar
Past owned:
An aftermarket made up cowl with some sort of '69-'70 Shelby NACA type of scoops attached.
Old August 28th, 2023 | 07:10 AM
zl1 camaro's Avatar
That's a aftermarket for sure
Old August 28th, 2023 | 11:14 AM
crossboss's Avatar
Past owned:
Absolutely agree! They should have installed the NACA scoops on the outer edges of the hood. At least that would have cooled the engine compartment....at least in theory that is.
crossboss
August 9th, 2023 10:35 PM
Bigmikey65
February 6th, 2023 04:38 PM
olds 307 and 403
May 3rd, 2018 02:12 PM
Rocketguy
September 12th, 2016 08:02 AM
